I started typing this out as a story and thought you guys might get bored reading it so Ill ask a quick question. When the thermostat is open and you rev the engine up the top radiator hose sucks flat. I think the only way that can happen is if the water pump is running in reverse.
I thought it was impossible to put a reverse rotation water pump for a serpentine on one with vbelts. The weird this is the outer casing is the right one, every thing hooks up like it always has and my water pump pulley bolts on just fine. Is it possible someone from the factory put the wrong impeller in the pump causing it to suck from the wrong side?
Did the first serpentine setups for the small block chevy use the same water pump as the vbelts, just a different impeller? I hope thats what is, I was pretty bummed out thinking my 400 cracked when it was bored. It also doesnt use any coolant.
Please give me good news guys
