From looking at the casting on the passenger side where the old style lower alternator/smog pump bracket would bolt that is for a V-pulley set-up. The serp water pumps don't have that casting there.
Buy the serp pump and remove the cover on the back and look at which direction the blades are on the impeller then remove the cover on this pump and compare and they should be opposite.
