B
bnc04
Guest
Hi all, What are you using as backup lights? I need them to be submersible as I often use the blazer to load and unload the boat at the local lakes which gets them wet from time to time. If I can remember to activate the switch and keep them off when doing this I could probably stop blowing out the lenses also.
I have them bolted under the rear bumper now and will move them to the receiver hitch when I do it again. I'll weld a tab on there to mount them this time so they will be a little higher than they are now.
Any recommendations?
Brett
I have them bolted under the rear bumper now and will move them to the receiver hitch when I do it again. I'll weld a tab on there to mount them this time so they will be a little higher than they are now. Any recommendations?
Brett
