quinryan
Registered Member
Inasmuch as I know that diesels are supposed to smoke some, mine smokes likes it was coal-fired instead of oil burning.
Even at idle I get a bit of black smoke (no white, grey or blue), and at anything over 1/8th throttle I can barely see the road behind me. Power seems okay, up until 3/4 throttle or more (I live in Colorado, so that happens a bit), when it acts like it is flooding out. That is, low throttle inputs are crisp. Big throttle inputs are "Huh? What?".
Important stuff- it's an 82 with the 6.2 and 700R4. The heads are refurbed with less than 100 hours on them. The IP is reman. The lift pump may be working properly, but it is augmented with an electric pump. The tank is clean and the lines are new. It has a HUMVEE's intake. (It would have had a HUMVEE's exhaust but I couldn't make the left one fit around the frame without a lot of torch work.)
Mileage seems to be a bit less than what I've come to expect (10-12).
It fires on the first try (usually on the first cylinder) and idles great.
Sooooooo.....
It seems to me that I am feeding the engine (way) too much fuel. Am I right in this? If so, how do I lower the fuel flow?
Sooooooo.....
