chuggins143
Registered Member
I bought my 90 K5 a few weeks ago and it's starting to throw code 44 which is Lean Exhaust which according to cfm-tech is an indication of "Low O2 Sensor Voltage". Now, it has what looks to be a brand new O2 sensor in it, and I don't just want to start throwing parts at this thing so where is a good place to start? Is there a OBD1 reader that will give me more info than just the codes?? ...maybe some sort of jumper or cable to plug into my laptop? This is my first jump back on the Chevy band wagon in a long time. (Probably been over 15 years since I owned my last bow tie)
Basically, what it's doing is when I first start it, it'll rev up to idle and then down to almost dieing and repeat about 5-6 times... then it'll just idle fine for a while, and after a few min it'll rev down and almost die again and rev back up. I can't see the RPM's since this truck doesn't have a tach... first manual rig I've ever owned that didn't have a tach, which I thought was wierd, but I digress... any thoughts or directions to other sites? Any direction or help would be much appreciated!!
Chad
Chad
Through the same penitration that the vacuum line goes through for the climate controls. Not sure what that wire is acutally for, but I can probably assume that it is not for the O2 sensor since both diagrams that I've been looking at show the single wire coming from the wiring harness. Ok, so now my question is does anyone have a clue as to what color wire I'm looking for?? Obviously this was hacked together and done incorrectly. My harness is looking pretty shabby right now, but I'm slowly making progress on cleaning it up... also, is the main wire bundle supposed to go over or under the brake booster assembly?
