398HBX
I just finished my 383 Stroker. During the initial startup (after about 150 degress), I noticed that several of my head studs were weeping water. I had installed them with Permatek thread sealant during the initial build. I have searched the web and even called Trick Flow and have not been able to find any definitive way to fix this problem. It seems like everyone has a "absolute best" way to fix this problem. I trust you guys here and I would like your opinion on which way I should proceed..
All options include removing one stud at a time, cleaning the block threads with a gun cleaning brush and brake cleaner
Option 1 - Permatex #2, Blue RTV
Option 2 - Indian Head Gasket Sealer
Option 3 - Teflon Tape (recommended by the rep at Trick Flow)
Option 4 - Permatex High Tack Gasket Sealant
Option 5 - Permatex Head Bolt Selant
Option 6 - Barrs Stop Leak Tabs
Option 7 - GM Coolant Tabs
Option 8 - Some type of aluminized radiator stop leak product
