MTMike
KidJethro said:It's a '95 2wd. I assume yours has the 70 out back? Hmmm....
Crap, and Crap.
Mine's a 4x4 (so I'd need a front 60 too) and it's a 60 out back.
KidJethro said:60 out back? In a 98? You sure? The 60 and 70 use the same cover...that could be confusing ya. I'm pretty sure there wasn't a 60 available in the rear on these trucks...
I'm trying to remember, I thought the white '98 he looked at had the auto and this truck had the 4500, maybe they are both autos now that I think of it.joez said:Didnt he say it was an auto with a fresh rebuild?
If it is an auto truck than 4.10's are pretty rare.mikey_d05 said:A regular Minnesota liscence is only good for combos up to 26,000 pounds...I'd have to apply for a bus driver's liscence with that rig![]()
rjfguitar said:I'm trying to remember, I thought the white '98 he looked at had the auto and this truck had the 4500, maybe they are both autos now that I think of it.![]()
Sorry for my confusion, for some reason I had it in my head it was a manual rig.KidJethro said:This truck is an auto AND 4.10's. Atleast according to the sticker under the hood. And 3.55's is starting to sound better and better the more I drive it around. Makes me uncomfortable goin much faster than 65-70 becuase the motor is screaming. That and it's totally out of power by 2400 rpm's.
I do however find it suprising that you have 4.10's, not that it's not possible because 4.10's were an option, but because I have never heard of a standard duty auto 3/4 having 4.10's. I would seriously consider a gear change to the much better 3.55's. i was thinking about it today when I was driving my dodge, about how 3.55's feels plenty low when you start to run out of "steam" at 60-65mph in 3rd gear. I can't imagine what it's like trying to do the same with 4.10's. As far as running it at the governor, I don't think the engine minds, my 24v spins 3K+ and it's basically the same engine besides the numer of valves, guys are turning the 12's up to 4K anyway, with new valve springs of course.
). I bet it wouldn't be real hard to find a 3.55 D70 with drums at a wrecking yard, and you could probably resell your current 4.10 version to the next yard down the street.
Any D70 out of a 3/4 ton '94-early '01 should work IIRC. an '01.5-02 may work but they have rear disks.70~K5 said:Remeber Joe that which ever RE you replace it with needs to be compatiable with your trucks ABS system if you want it to work right.
70~K5 said:In GM gas trucks
It seems you have learned a lot in the last few months.84_Chevy_K10 said:Forget everything you know about gas trucks when referring to the Cummins. . I drove a 4.10 geared, 6 speed Cummins truck and I instantly knew that 4.10s were not for me. The narrow powerband and close ratios of the 6 speed resulted in an obscene amount of shifting.
I opted for the 3.73s as a result. 3.55s would potentially be even better--especially with the shorter tires like Joe has.
I remember "someone" applying their gasser knowledge and refering to 3.55's as "air plane" gears that couldn't pull a string out of cats behind...
You've come a long ways....Our 24v's do but his 12V redlines at 2500.It redlines at 3,200 RPM
84_Chevy_K10 said:Forget everything you know about gas trucks when referring to the Cummins. It redlines at 3,200 RPM. I drove a 4.10 geared, 6 speed Cummins truck and I instantly knew that 4.10s were not for me. The narrow powerband and close ratios of the 6 speed resulted in an obscene amount of shifting.
rjfguitar said:Our 24v's do but his 12V redlines at 2500.
It will spin 3K? Someone changed the governor already for you. Stock 12v's are set at 2500 RPM's.KidJethro said:My truck redlines at 3k.
84_Chevy_K10 said:My point exactly.
70~K5
Ford has never used an I6 Diesel in a pickup. Comparing a V8 Diesel to a Cummins is like comparing plums to watermelons.
There's plenty of slow speed control when you make 450 ft lbs of torque @ idle.
