- Joined
- Mar 3, 2000
- Posts
- 9,122
- Reaction score
- 7,075
Wiring is not my forte'
So after leaving the jimmy sit for about 5 weeks it was dead, No problem trickle charger for a while and it fires up. Run it down the road about 30 miles and around town off and on the next few days and all is well. I did notice a couple times kind of sputtering at low speed or just after shifting, seemed electrical.
Leave it sit for a week, no start, ok same thing. Then leave it sit another week, dead again. Ok I am thinking battery since it starts but then after sitting it doesn't.
Today I hook up the charger on 2 amp and while I am in the garage I hear a click every couple minutes. first one is kinda loud, 2nd one quieter and this keeps happening. So I go over by the truck and notice that the click is from my battery charger and when the loud click happens the guage goes from zero charged to pegging the other side of the guage like overcharged, then on the 2nd click it goes back to zero charge.
So I take the charger off try to start and no dice, it had enough juice to fire the fuel pump but not turn over. So I jump it. Drive it 15 miles shut it off for 10 minutes and its dead again.
So jump it and drive 25 miles and leave it run, then put a volt meter on and its 12.5 volts while running, a guy I know checks out the alternator and says its not charging much and the meter showed 7.5 volts, then he starts looking around and says the old voltage regulator on the core support is hooked up even though your alternator has an internal one. He checks a wire and notices a voltage fluctuation. thinks we need to unhook the old style voltage regulator and get rid of the wiring.
1970 GMC Jimmy
350 TBI from a 93 Suburban
Howell harness and computer with proper chip, been running for 3 years this way.
4 year old optima red top battery
any advice? I have a test light volt meter, ohms etc and some limited knowledge. Planning on having a friend fix it in his shop but figured the more I know the better. Thanks.
1970 GMC Jimmy
