k20
3/4 ton status
Ok, weird problem was wondering if anyone had an idea. First the specs, 496 with a Speed Demon 850, a th400 with a 2000 or 2400 stall (honestly cant remember). Truck idles at 700 in gear 1100 in park/neutral. Now for the symptoms. Running down the road its fine, great throttle response. Regular stop and go its fine. Normally the temp runs about 185 and the trans temp is 120-140 depending on how hot it is outside.
Now here is where it starts getting odd. Sitting in 5 o'clock traffic the engine will heat up to almost 200 but no higher (not really weird). The transmission will heat up to almost 180
(that is being read at the pan btw). After sitting in this traffic, if you hit the gas, there is nothing as far as power goes. Wont rev past about 2200. Pop it in neutral and it revs loud & proud, pop it in gear and there is nothing, even starting off with the shifter in 1 it doesnt wanna pull past that 2200 mark. Also in D it seem to shift sooner than normal.
The tranny fluid is at a good level and isnt brown or burnt at all, still nice & red. Am I losing th400 #4, or is it just overheating the tranny causing these weird symptoms.
I would think vaporlock but it revs good in neutral and I have a bypass fuel system (electric fuel pump).
Any ideas?
(that is being read at the pan btw). After sitting in this traffic, if you hit the gas, there is nothing as far as power goes. Wont rev past about 2200. Pop it in neutral and it revs loud & proud, pop it in gear and there is nothing, even starting off with the shifter in 1 it doesnt wanna pull past that 2200 mark. Also in D it seem to shift sooner than normal. The tranny fluid is at a good level and isnt brown or burnt at all, still nice & red. Am I losing th400 #4, or is it just overheating the tranny causing these weird symptoms.
Any ideas?
