badmix
Ok, Im not one to sit around and be glad a problem fixed itself, I want to know why it happened in the first place.
I hadnt drove my truck in 2weeks, fired it up and a belt squealed, first time its ever done that, just figure stuff was stuck from sitting. Drove it 45min, shut it off (this was daylight hours). after about 2.5 hours, its dark now, I start it, get a squeal for a split second and then turn on my headlights. The drivers side headlight, parking light and turn signal indicator are glowing a weird dual brightness, not the same as passenger side. My turn signal works, but the green light on dash will stay lite.
Drove truck about 20min, monekying with highbeam, turn signal, turn lights off and on, etc etc. nothing happened, and then just driving the green light slowly went off. I tested all lights and turn signals, all worked fine and normal. So WTH, why would I get a weird glich that would just fix itself?
Now, prior to this.....
1) I was under the dash hard wiring my CB (didnt touch factory harness)
2) day later Tach stopped working
3) same day lights acted wierd
My thought is that the squeal was alternator belt and it wigged it out and caused system to act weird and once alt. got its crap together decided to make things good again.
ANyways, I plan to get under the dash and check fuse panel to make sure some arent 1/2 way in or anything and wiggle wires around
anything else to check?
Thanks
Thanks
