Joe In Montana
- Joined
- Sep 9, 2016
- Posts
- 283
- Reaction score
- 109
I used to have this problem with my 75 with a neutral idle speed of 800 RPM or more. My base timing is 10*btdc, not too low and not too high. I always used 91 from Shell or Chevron, and the engine was squeeky clean inside, no carbon build up, confirmed with bore scope. The throttle plates of the qjet were just opening too wide at that idle RPM causing the dieseling effect. I found a working anti dieseling solenoid from a Corvette, installed it on the 4MV Qjet in my truck and Bingo! Problem solved.
GM used anti-dieseling tricks for a while - especially in 1968-1975 or so.
In those years the emphasis was on HC and CO emissions with little regard for NOx.
Does anyone remember the extreme heat they would feel when they touched their hoods or opened the hood and had the blast furnace heated air hit them in the face? That was an attempt to control only two parts of the smog problems in SoCal.
This heat was from the retarded timing and ridiculously lean fuel and other engine settings.
One trick was to turn the AC compressor ON for 15 seconds with a delay-relay. This was an attempt to 'drag the engine' to kill it once the ignition was turned OFF.
Another was that the carb had a solenoid or vacuum diaphragm that allowed the idle speed to drop when the ignition was turned OFF.
A few transmissions had the output from the front pump, diverted to a very small orifice that substantially gave a lot of hydraulic resistance to the front pump turning, resulting in dragging the engine to a halt.
It all helped - some!
OK - the reasons why those engines of that period were afterrunning was from
1) increased idle speeds. (typically ONLY in Drive/Reverse, but basically held there by a anti-dieseling solenoid on the carburetor)
2) lean air:fuel mixtures. (up to 17:1 - originally the optimal A:F ratio is about 8:1 or so)
3) 195-205 F engine coolant thermostats. (originally 160 F)
4) retarded timing (up to about 55 MPH when ignition timing was allowed to advance a few degrees).
5) lowered octane values in the gasoline, also there was no tetraethyl lead in the fuel any more. Lead-Free was the new gasoline, ca: 1973 in California areas of Non-Compliance)
Here comes a technical lecture - I warned you!
The following information is scholastic - as it has had an impact on the problems in the OP. I think it might be interesting to read about the genesis of the vehicle emission control systems of today.
[soapbox]
(then).... there was the California 1966-1970 Retrofit NOx systems that everyone screamed and yelled about.
The fact that there were used-car dealer 'Kar-Kits' that cost $6.95 and consisted of two rubber vacuum nipple plugs, some green RTV and stickers to seal the increased idle speed and ultra lean mixture adjustment, retarded ignition timing except on Ford CBZ-style vacuum advance ONLY type- distributors, and a sticker on the speedometer that warned the driver to NOT drive at speeds of 55 MPH for more than a few minutes or overheating might occur.
The first two were actually capacitor-discharge ignition (CDI) systems that actually created an EXEMPTION for the vehicles upon which they were installed and made the engines run much better!
The Carter Kit however, was not an EXEMPTION, but was intelligent enough to actually measure the upper radiator coolant temperature and advance the timing override to help return the engine to a lower and safer temperature before it self-immolated.
The Kar-Kits could not sense the engine temperature and they were singularly responsible for the whole '66-'70 Retrofit NOx System failure I believe.
Well - sorry for digressing there with that tirade. I was a California certified Installer-Inspector-Adjuster from the beginning of the 'SMOG' or Clean-Air pact that California had declared war upon. I originally installed the (also) much hated CV/KV Crankcase Control System in 1963.
We had to drill holes into the vacuum side of the intake manifold using a pencil magnet to pull the drill shavings out of the manifold --- and add a diaphragm-controlled 'smog valve' --- to suck the blowby out of the crankcase.
It originally was a US Army idea to capture and send-to-combustion the escaped fuel and fumes that would normally be vented to the atmosphere. It was a fuel economy device - believe it?
Bottom line here:
After-running or 'dieseling' is from just a few reasons - most are controllable - by using a better grade of fuel, setting the idle in Neutral or Park, adjusting the carb to a decently rich mixture of about 7:1 at idle only, and keep the timing at a decent value.
Ergo: it's a product of timing, mixture, idle speed, fuel octane rating.
Engine compression figures are in here too - but not logically since most engines built after 1970 or so, are relatively low compression.
Remember this though: the timing MIGHT read incorrectly --- and that's possible if the timing chain is badly stretched, causing a false timing reading.
In the meantime - and I know this has been said already: shut the engine off while the transmission is in any gear - forward or reverse - to have the torque converter 'drag the engine to a halt' *.
[soapbox]
Used car dealers and unscrupulous CalARB installers didn't put the warning sticker on the speedometer.
These Kar-Kits were super el-cheapo for the used car dealer trade --- but there were some very good and therefore much more expensive units such as: the Pure Power and the Contignitron and perhaps I'll include the Carter Retro-NOx Device here too.The first two were actually capacitor-discharge ignition (CDI) systems that actually created an EXEMPTION for the vehicles upon which they were installed and made the engines run much better!
Bottom line here:
* The parts inside the transmission don't actually form much or any drag when they are standing still. It's the torque converter that's doing all the slipping and dragging. If the rear wheels aren't moving - there are no parts except the front pump and a stator and maybe one of the concentric stator supports that are in motion - depending on the transmission type of course!
[/soapbox]
[/soapbox]
