I like moving my front axles forward, even so far as to have to relocate the steering box. I have never tried the arms that put the tie rod behind the axle, those may be my best solution but its kind of an expensive solution.
I plan to link Horton ( my truggy) this winter/ spring. Like many others who have done the 52/56 swap I have found the limits and the fact I know I will need new springs every year or so sucks.
I do not want to put my tie rod back down to the stock position ( another option I am looking at).
Who has used the double ended arms?
So to keep high steer and to keep my current arms (ORD) what is the collective thinking about bending the draglink forward. So the bend in the drag link will aim it forward enough to get it out of the way of the tie rod, not sure if its reasonable to bend it and clear everything else but its something I have thought about.
Anyone ever done it, seen it done, thought about it. I want to move my axle 3-5 inches forward.
Yes I know full hydro is the easiest way but right now kind of out of the budget. I don't want to link the truck twice (well twice on one end) so I want to get it linked and moved up with semi conventional steering then switch to hydro later
