I've got a transmission issue on the '94 Burb. At 68 MPH, the torque converter cycles rapidly in and out of lockup (about 2 seconds on, 2 seconds off, back and forth). It's kind of unnerving and actually jolts the truck pretty good - I'm sure it's also not good for the trans.
I did a run and captured the ALDL data, and it appears that the lock/unlock fluctuation is being commanded by the ECM, but I can't for the life of me figure out why. The jolting is a result of the TCC duty cycle going from about 90% to 0% and back instantaneously (versus a gradual dropoff/rise).
The TPS voltage does not fluctuate when this happens (I thought maybe I had a bad spot in the TPS). The problem is very speed-dependent.
Any ideas out there?
