Had to go get a blood test at 7:30 am today--was surprised my 6.2 started,it was about 18 degrees,and I didn't have the block heater plugged in..thing started OK,but sounds like more than one cylinder has a dead glow plug,it stumbles badly and will stall if you dont hold it at fast idle for 2 minutes or so..but that wasn't the issue I had that is puzzling me..
I had two tires put on the front recently--old BF Goodrich TA radials that are 10 ply..the truck rides like they are not perfectly round after you first drive off,but smooths out after a short distance..I assume they are worn from whatever vehicle they were on and it'll be awhile before they "wear in"..they don't have much tread and have wear of one edge more than the rest of the tread..
I drove the 3 miles to the lab ,got the blood drawn,and was back out the door in 5 minutes--I drove home ,had to take the "longer" route to avoid having to fight crossing 2 lanes of heavy morning rush hour traffic..
Everything felt "normal" on the way home,until I had gone maybe 2 miles--when I came to a intersection and had to stop,a billowing cloud of smoke was coming out from under the truck--it smelled like burning brakes or clutch (its a TH400 so that counts out a clutch!)...
I couldn't pull over and check it out right away until I got away from heavy traffic,and I saw more smoke bellowing out behind me..I feared the truck was on fire,or about to be,didn't know if wires were burning or what,but it didn't smell like burning wire insulation..
I got out and hastily peeked under the truck,with it running in park..
No leaks I could see dripping underneath it,and no smoke,but it did stink bad like the brakes were dragging..I couldn't park there for long,so I got back in and drove the 2 miles the rest of the way home,and saw no more smoke,no odors..
When I got home,I got out and felt all 4 rims ,to see if any were hot,like the brakes were dragging..all 4 were ice cold,even the front calipers were not warm at all..
I checked under the hood,saw no leaks,and the radiator was full,and had pressure when I opened the cap,so its not a coolant leak..still no sign of anything under it had leaked either..
All I can think is maybe the brakes got soaked Saturday when I drove it about 5 miles each way to a store and back in heavy downpours,and the moisture made the rotors or drums rust up while sitting all day yesterday,and it burned off ?..
..but I find it strange no evidence of a sticking caliper or wheel cylinder existed..
Maybe the "out of round tire" feeling I get after a cold start when it has sat a day or so is a front caliper sticking,I don't know..but I'd think it would have been hot as hell by the time I got home,even if it had freed up after the smoke show,where it happened isn't that far from home,I doubt the brakes would have cooled off that quickly..
Not a good start to the week....
..but I find it strange no evidence of a sticking caliper or wheel cylinder existed..Maybe the "out of round tire" feeling I get after a cold start when it has sat a day or so is a front caliper sticking,I don't know..but I'd think it would have been hot as hell by the time I got home,even if it had freed up after the smoke show,where it happened isn't that far from home,I doubt the brakes would have cooled off that quickly..
..Not a good start to the week....
