So here's what I have, 14ff, CV driveline, 205, 465. U joints are good and CV is fairly new. Shaft has been balanced and is not missing weights.
Here's what it does, above 5 mph it develops a vibration, similar to an out of balance driveline, only more so. But it does not do it all of the time. It goes in like 5 minute cycles of on and off. Increases intensity with speed.
Does not do it with the rear driveline removed. Does do it in either 4wd or 2wd, does it both under power or coasting. It is not engine or engine speed related, any gear.
So, fire away with your thoughts and suggestions. I have a few theories, but am choosing not to muddy the waters yet...
