I was only going to fix the rust in my rockers , by cutting them out & putting in some square tube ,,,,
Well I found more rust & then more rust & even some more rust ........
and that tub was from Arizona .....was rust free ......with very limited winter road driving
ended up chopping the whole tub up & getting another tub from texas ....
Got lucky & found one cheap & local ....
This time I sand blasted cleaned primed/sealed & sprayed the floors inside & out with Raptor bed liner...
Still working on putting it back together , but it will last a bit longer this time ....I hope
Like was already stated , need to decide before you start what your desired end result is & figure out how much time you want or have to achieve that result....
I in the past , trying to save a few bucks . decided I would replace the rockers & cab corners on my
86 K30.... well that turned into both floor pans , inner kick panels , cab floor braces , body mounts , inner & outed rockers , inner & outer cab corners ........ect ...ect ...ect ....
Well a one or two weekend project turned into a 2 months battle with where & when to say good enough ....
Basically in the long run I could have went & picked up a rust free cab , scuffed it ,painted it & been driving my truck in a weekend easy , for waaaaayyyyy less than what it actually cost me to fix a lil rust .......
View attachment 190660View attachment 190661 View attachment 190662
View attachment 190644 View attachment 190651 View attachment 190652 View attachment 190653 View attachment 190655 View attachment 190669View attachment 190665 View attachment 190666 View attachment 190667 View attachment 190668
