weld on bead locks
MNorby
3/4 ton status
Powell, Wy
Found a thread on pirate once and can't now but it listed all the weld on beadlock kits. What all ones do ya'll know of and any pros/cons? I am looking for a kit that INCLUDES the hardward too.Thanks
I got mine from rockstomper back in the day and haven't had a single problem since. They do cone but no leaks to this day. there are quite a bit more vendors out making these now.
Pros,
Cheap compared to alternatives.
Customizable
Durable
Protects the rim
Personally I love the look as well
Cons,
They do cone in (if you want to call that a con some folks like the look it produces)
Some say illegal (I've been pulled over with them on in a strict state and nothing was said)I have yet to see it in black and white.
Rim is permanently altered.(if you want to call that a con)
They don't lock the inside bead. Cheap ways around this as well.
Generally I don't do bolts with them for the simple fact that the weight of the bolts would require them to be sent in a different package which negates any savings I could give you short of picking them up at a local hardware store. I also have seen instances where a shorter bolt could have been used. I'd start with 1.75", 1.5" will often get it done.
I was going to stay out of this thread as I am biased but hey, there it is. Fair as I can be.
I was gonna buy some DIY4x ones until you found me the those H1 wheels and DRW axles in the same week :)
Kert's work is top notch.... I'd go with his.
Kert - I've heard that they're not "DOT approved" but are legal. :confused:
With weld-on beadlocks, you are substantially altering how the rim works.......so technically you are voiding the DOT- approval that the rim has when stock. Therefore, again technically, the rim is not legal for use.
However nobody has been able to produce a vehicle law that specifically states a "beadlock" is illegal. There are companies that make beadlock wheels that obtained the DOT approval with the beadlocks.
I'm not worried about legality and such. A friend is buying me a set along with himself if I do the welding on his (he got frustrated at his 16.5s last weekend). Money is really no object to him so wanna get the best and was thinking of getting the hardware too to make it all in one bill kinda deal.
