Weld these cracks or replace the pans?
Greg’s 89 GMC Jimmy
Registered Member
Hayden Idaho
Good afternoon. I recently bought a running project 1989 GMC Jimmy that will be slowly restored and is for my son, Greg. First things first are the cracked/slightly rusted floor pans. Seems this is common. Truck is from Oregon and barely has any rust. Would you brace and fix what I have here or buy new pans? I am leaning towards fixing what I have.
I am also replacing the seats front and back. 2000-2007 Suburban 3rd row for the back and leaning towards 96-99 Silverado seats for the front. Thought about the same year 00-07 Suburban/Tahoe seats with the integrated seat belts, but wouldn't know what to do with the holes in the B Pillar for the current seat belt configuration. IMG_2403.jpg
Have uncover the metal and see how badly rusted the area is. If just the cracks and no cancer I would weld them up
I agree with Wes. Weld them up and maybe add a little extra metal between friends. I really should look at the seat attachment locations under my Jimmy. I honestly have no idea what they look like.
Joel
norcal
Mine were cracked worse than that. The tops of the high back seats were touching. No rust. Welded them after hammering back together. Then built a cage to mount the seats on.
a cage for the seats or one to keep you in?
I was changing to a different style of seat so I welded up the cracks. Mounted the new seats with some bracing. If you put the stock seats back in you should probably reinforce it when you are welding it up.
