What does your fully locked rig drive like on the trail? I imagine not being able to turn, but I've never done it. Do you unlock a hub sometimes just to make it more drivable? Thinking of welding my diffs until I can spring for some lockers.
I am welded in the front and a Detroit in the rear. Trail only and as mentioned above with hydro assist it's no big deal. I did one trip without hydro and couldn't steer at all. My welded front was supposed to be temporary 4-5 years ago, but it just works so it's hard to justify $800+ for a locker.
Had spools front and rear, with no Hydra just cross over steering on 37's. With both hubs locked, I was to able to turn on soft stuff (Cinders, sand, soft dirt) pretty well, on rocks or street, tacky dirt it was nearly impossible and if I did, they wanted to straighten back out when on the gas.What does your fully locked rig drive like on the trail? I imagine not being able to turn, but I've never done it. Do you unlock a hub sometimes just to make it more drivable? Thinking of welding my diffs until I can spring for some lockers.
No 6000rpm dumps here.i've heard both ways on that. Some people say that shock loads it more than fully welded, because it has momentum and then suddenly stops at the welds. I welded mine solid and it's been going strong with 6000rpm clutch dumps. I don't know which is better, but if yours has held up that long it must not be too bad.
But 44 Boggers on the rocks will put a strain on things. I would think a Detroit with it's 1/4 to 1/2 turn backlash would put a pretty hit on a axle shaft. I can barely turn the driveshaft before things start turning.No 6000rpm dumps here.But 44 Boggers on the rocks will put a strain on things. I would think a Detroit with it's 1/4 to 1/2 turn backlash would put a pretty hit on a axle shaft. I can barely turn the driveshaft before things start turning.
