I have what you're asking about
78Suburban,
I am running this setup in my 78 Jimmy. I have a 203, and a welded 12 bolt rearend. I don't mind at all having the rear welded, as it is not a daily driver. The truck does have a little bit of the "push" they were talking about, and the tires leave stripes and make noise around corners. The thing I hate is that BS full time transfer case, heres what I do with it. I have lockout hubs on the front and I run the T-case in "Loc" with the hubs unlocked when I'm just driving around. I lock the hubs in as necessary when wheeling. When you run your full time in "H" or "L" (not Loc) thats one more open diff to deal with, and I HATE open diffs. When you put it in "Loc" it locks the diff out and locks both driveshafts together. With my setup I just have to use judgement in the given situation for which range the T-case should be in, or if the front hubs should be locked or unlocked. I absolutely can't drive it on pavement with the hubs locked in and the T-case in "Loc." I haven't tried it but I know something will break if I do. Hope that answers your question. Kevin
