Welding aluminum and mild steel
Welding Aluminum with a MIG Welder is not difficult at all. You need to use straight Argon as a shielding gas and a Nylon Liner to keep the wire from hanging up. Of course the best way to go is to use a Spool Gun so that wire jams are not a problem. I bought my Miller 200 and Spool Gun over ten years ago to build several hundred feet of Aluminum ornamental deck railing for a multi-million dollar oceanfront home I was remodeling. While I was at it I used left over materials to build an Aluminum rack for my rig. It is light enough that I can put it on by myself, even with the Hi-Lift bolted to it, and I have had six big guys stand on it for hours while watching a desert race. As someone noted, you do have to weld a little faster than you would on steel.
I saw some aluminum or magnesium rims with steel centers welded into them--I didnt know it was possible to weld non-ferrous metal to steel until I saw that!.I didnt beleive it till the guy showed me a magnet would stick to the centers,but not the aluminum or magnesium outer part of the wheel--the beads looked perfect--but I dont think I'd trust my life on them!. /forums/images/graemlins/yikes.gif
