Hey guys!
I need to weld my NV4500's bellhousing up. It has a crack running from where the external slave cylinder's upper bolt goes through the bell on the passenger side, and all along up the side to just behind the top right bolt on the passenger side
I was still able to use the clutch on the truck right up until I removed it, so I only really need to stitch it back together. The material is pretty thin the whole way up, less than 1/4" thick.
I have a 110V MIG welder at my place, equipped with a 75% Argon and 25% CO2 shielding gas mixture. I was told that I can just buy a spool of aluminum feed wire and weld the cast iron bellhousing without heating up first, or worrying about the metal around the weld cracking.
Is that true, or is there more to welding cast aluminum? Seeing as the whole bellhousing is covered in grease, is there going to be concerns of a poor weld due to the now impregnated oil?
Any other suggestions?
Thanks!
Thanks!
