71 Blazer
I have a bit of a problem. I have a mud bog to go to on Friday and need my 76 GMC to go. I recently found out I have a cracked block, I thought it had just popped the freeze plug. I have a mig welder and think I can weld it up. I have never welded on cast before. I have read that it should be heated up with a torch first so it isn't so much of a temp change, is this right? Any help will be appreiciated. I am going to put the freeze plug back, and will check back with you guys in a bit.
