Ok i have a 3/8th plate of steel that seems to be galvanized. How do i go about welding it without any ill effects? Do i just grind clean the area that i will be welding an a lil farther back or is it even possible without an acid soak? thanks guys!
get a good dust mask the ones we have at work are from 3M and say for welding fumes or to really be on the safe side get a respirator with charcoal and HEPA filters like used for spraypaintinghmmm yeah i was lookin round google for it.. im gonna prob just ditch this piece of steel and grab a regular one... haha dont feel like risking getting welders flu...
) and luckily didn't get sick either.it should remove most of itThat will remove the galvanizing?
http://www.sperkoengineering.com/html/articles/WeldingGalvanized.pdf
Here is an article I searched and found a while back when I had to weld a fender on a galvanized boat trailer. It has useful info on breathers and restoring corrosion resistance.
I did it outside and had a fan on lo blowing the smoke away from me (but if you are using a shielding gas, this might not allow that to work properly). I also tried to only weld in short segments and walked away to let the smoke dissapate before coming back to weld another segment. I didn't drink milk (hadn't heard that one) and luckily didn't get sick either.
