lectric80
3/4 ton status
I am getting ready to put a patch panel into the B pillar on Krusty. This panel is to repair the busted out door striker bolt that I did a temp repair on last year. I am planning to cut up an old tailgate access panel that I don't need, and then make a dual layer patch panel to weld into the pillar.
My question is that I had heard at some point that when doing this type of patch panel that the corners should be rounded to help prevent stress cracks. Is this something I need to worry about, or would 90* corners work just as well? This is something that is obviously going to see a lot of force at times, and I want it to last for a good long time.
By no means am I an expert welder, but a good stitch weld in this spot I can accomplish. I am just tired of listening to the door rattle because the original patch was some pretty crappy sheetmetal that isn't holding up well. The dual layer patch should provide some stability for the bolt, but I don't want it to fail again.
So, what say you?
Edit: It should be obvious, but a square edged patch panel would be easier to cut out of the pillar. However, I want this to be as strong as I can possibly make it, so I will do what needs to be done to ensure it is solid.
So, what say you?
