hawkeye649
[ QUOTE ]
Yeah gas weld! I have been told if you can gas weld (good of course) then you can weld anything.
[/ QUOTE ]
True true. I could runa gas bead that was good enough to rip along side the beat with 20 ton press. I would attach a small piece of steel to the back and bevel the hell out of the edges. Clamp it all up and then fill it up with steel. Grind it until it's completely smooth and then cut it across the weld, and bend one one way and one the other way. This is the best way to test a weld 84gmcjimmy.
[ QUOTE ]
I was gas welding today and was doing pretty good. You can get a gas plant pretty cheap and its not a PITA like stick either! /forums/images/graemlins/thumb.gif
[/ QUOTE ]
I hate MIG, I would rather use an oxy-acetylene torch.
My fav is a good 100% duty cycle DC welder runnin a piece of 6010 1/8". Doesn't get better than that. (envision a hard on graemlin)
What is that stick you pussies use with the soft flux, 7011? Sucks dick! /forums/images/graemlins/whistling.gif
[/ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
