Engineering standards vs welding to a light duty vehicles frame is like citing international war criminal evasion laws in a Jay walking case. It's just so out of the league of forces it's stupid.
This could not have been said any better, haha
Just weld that shiz to the frame and don't worry about it. Everyone always thinks they may want their sliders to either be removable or worry about damaging the frame....it's a 25+ year old frame anyways, it's not perfect and I doubt you will ever want to remove your sliders. I just welded the tubes to the frame and then did my own tabs that were welded to the body mounts (similar to Kerts design, I just made them and welded instead of bolting). I have hit them really hard mulitple times and the sliders and frame look the same as the day I put them on
All of the above.
Do you think these light duty frames were tossed together in someones back yard or engineered using these same standards? I would venture to guess that engineering standards were used to design and manufacture 100% of automotive frames on the road today
You can weld to a frame and not cause problems because you know what you are doing or you just get lucky. Or you can introduce unnecessary problems and have a failure on the road. I wouldn't care if a weld failed on a rock slider, I would care if my frame failed.
Suggesting someone learn some basics on the dos/don'ts of welding on a frame is should make some sense to you.
Holy balls man...Are you for real?
These are mild steel truck frames. The only way a truck frame fails from welding anything to it, is if there was something structurally wrong with it in the first place. They will NOT just up and catastrophically fail from a weld. Think of it as a tractor as far as that goes. Weld away, worry free. Go look at 99% of new frames these days. They all have welds on them. Common sense applies...if you've never welded anything before, have a friend do it, or learn yourself. It's not rocket science in this context.
You aren't helping people by telling them all of this and quoting things from AWS books or structural steel welding practice regulations etc, you are confusing them and making something simple sound very complex. I have held the certifications, I have been through the classes and I have a life time of experience with this sh!t. From truck frames, to structural steel, to ornamental iron work, to chromo tube chassis ultra4 cars.
