original balzer
Turned out my CC frame was cracked as I mentioned b4 in another post.
A friend of mine who used to work at a body shop fixing frames came by and welded it up. It wasnt as long as I first thought the crack in the frame was only about 1.5" long the rust scale covering it had a crack about 3" long. He ground it down and sorta v'ed the crack welded it up and ground it down smooth cant even tell it was there.
Now the question is. He said we should go ahead and weld the spring hangers on the rear. Do you think its safe to trust his welding if he has a good history of welding/straightening frames? I went ahead and let him start on it. We pre heated the frame and hanger, he welded a few sections, and said it needed to cool and he had some things to go do so he will come back and finish later.
I want to bolt on the front hanger at least until I get shackle angles good. I lopped off about 5'7" of the frame. If my figures are good it should be 11' wheel base. Aout the same as a reg cab long bed.
For pics and better explaination check my blog I should have most of it there in a day or 2.
Balzer
Balzer
