BorregoK5
Re: Well, a TH350\'s bellhousing can\'t take a 415ci!!!
Well it slight outside and I finally got a good look at the bell housing. I can see where the bellhousing had fresh breaks and what look like old breaks connecting them. The tranny rotated just enough tocreate a circular break spanning from the center of the access shield up and over to the same spot on the other side. I jacked up the tcase and found a little movement on one side of the crossmember mount sugesting that it could rotate a little. Everything else is was tight. Dropped a cherry picker on the motor and pulled at the mounts but it was very tight and didn't move. I ordered the JW Trans ultra bell which Donovan suggested looking into. After spending some time on the phone with them and discussing some of the prep work (like cutting of the stock bell) and the streangth of the replacement bell, I had them overnight it.
Have any recomendations for poly mounts? I usually go PST...
I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
