So it appears a previous owner wanted to lift this truck so high it's almost impossible to climb in, or do anything under the hood without a ladder or tall step stool.
First, he installed a 3" body lift at all body bushing sites.
And I guess then he either altered the springs or replaced them with a high lift type.
It's currently 11.5" between the top leaf (RF) and the bottom of the frame. Can someone please measure this same area on your K5 and see what I've got here compared to yours? The top of the radiator support is right at 5 feet off the ground. I would prefer something at stock or maybe 2" above, but it is very difficult for me to even get in the cab w/o a step stool as is. Also not shown here is a 3" - 4" thick lift block between each rear spring and rear axle. Also, the truck has 15" wheels with 33's....(which I kinda like)...
So.......What do I have, and what do I need to get this thing manageable? Thanks, Lee
Steps will probably be in order for me too. Right now it's all I can do to pull myself up and in, holding onto the windshield frame and the roll bar.... (it ain't a very pretty sight)
