I'm doing a gear swap and locker install on a 2003 Tahoe with an 8.5 rear end and I've had nothing but problems. All related to the wrong gears being in the right box.
The owner ordered this first:
Got it out of the box, and...
yeah, that ring gear looks a little small... turns out it was like 7.25", so he returned that and decided to go with Yukon gears.
Ring gear measured out right, but was a bitch to get on the carrier. Unfortunately, again, not the right gears in the box.
I don't know what those markings are, but it's not Yukon markings. When I tried to install them in the diff, the ring is impacting the pinion, even with all of the shims pulled out of the left side.
Looks like its a thick gear set, but I can't make anything from the numbers on it, so it might not even be for a GM 8.5.
3rd set of gears is on the way. /sigh
