SCOOBYDANNN
Got to do some real wheeling up in Las Cruses--did Rocotillo rapids. Real good day up until the sunny skies of the southwest get real black real quick.
What I learned; If you get a flat and no one has a high-lift wou can tie a winch to the top of tha cage and basically almost roll it over and change a tire.
Quadrajets; most definately the best offroad carb does have its limitations. when pointing the nose straight in the air (still running mind you) can and will spill fuel out, gravity then takes hold and lures the fuel right to the distributor, thus lighting my truck on fire---sorry; no pics kinda busy
wet rocks do not make for an easy ascent on a near vertical ledge
my bumper needs to be shortened--BAD
and Ipod earphones hurt--BAD
The day started off great. I have no trailer so I drove up through the desert for about an hour and met them up at the air down spot. The whole day we were just crusin through. I did the v notch (they didn't want to do it cause of the axle width and it just spit you on the side.
first obstical
looks like the wrong line, but it's not
The second obstical had a line for driver drop and pass drop. The Jeep and Bronco took the driver drop line. this jeep has been rode hard and put up wet
Tony's "bronco"
Me and the red jeep had to take the pass drop line (duh?)
basically a Chevy with a Jeep body.
this waterfall took a swing at three trucks but we all made it out. Tony's bronco got a flat, rolled Adrians Jeep and lit my truck on fire.
silly jeep
first obstical
Tony's "bronco"
silly jeep
. Danny, if you have some Vacation, you should come on out and check out the AZ wheelin
