So I submerged my blazer (91 5.7 tbi) sat over night until pops could bring the winch out. Anyways. Trailer it home. Spin the spark plugs. Purge the water out, drain oil. Plenty of water. Drop the oil pan, sand, white built up sludge, cleaned also cleaned the oil screen. Replaced oil. And starter. Fired up ran smooth other than lots of white smoke (thought it was steam and it was well below freezing outside) and water filled muffler. Figured it would be ok after I got the water out. so i drained the tranny. New Filter etc. Serviced the diffs and xfer case. Pulled it off the trailer started checking everything else out I could think of. Then at idle my oil psi dropped (autometer gauge) enough to trigger the ecm to shut er down. Dropped the oil pan again found more sand. Cleaned everything I could. New oil. Pressure is looking good. After a few minutes I start hearing a squeal and knock combo. Bottom end. And also a valve train tap. oil psi looks good. Shut her down still white smoke (no oil in coolant or coolant in oil. All fluids look good. Never have I overheated er. Any ideas? Sanded out main bearings, oil flow prob/blockage..
