What air pressure do ya run front, rear?
dontoe
3/4 ton status
Hickory, N.C.
What pressure do ya run on yer DD?
Front tires/rear tires?
What type vehicle?
And I suppose the size/type tire would matter!
33 inch radial Sport Kings . I have run a slow as 25 psi , as high as 35 psi .
I have found the best balance between ride and handling is 28 psi . Perfect tire wear too , rotate often for the rear locker though so no one tire gets too much wear .
I wish I had a tire machine , damn tire shop always airs them up too much . like 40 psi , and then I have to pull over and air em down :k5: :k5:
Normally I run 28 rear and 32 front. Have for years with 33'' BFG's. Trying that with the35 BFG's seems kinda bouncy!
its not a DD, but when i do drive it on the street it is, 15-14 in the front, and 13-14 in the rear. 39.5 boggers in the rear, and TSL's in the front.
i run 30 in the front 26 in rear w/ 35x14.5 SSR's......actually I havent checked em in a while.......need to go check em when it quits raining.
6800 lb K10 on 44" boggers (15x12 wheels): 18 front 15 rear for highway driving, 15 front 12 rear for general around town and off roading locally, 12 front and 8-10 rear for the bigtime trails like Tellico
'89 Dodge Dakota 4x4 with 325/60R15 BFG A/T on 15x8.5 wheels: 32 front, 28 rear
97 Dodge Ram 1500 2wd with 275/70R16 Dunlop Radial Rover A/T on 16x6 wheels: 35 front, 32 rear.
98 GMC Safari with 235/70R15 Tech 5000's on 15x6 wheels: 35psi all around.
36" tsl radial swampers. I think there at 35 or 40 psi. so far after an year are so they wearing pretty good.
31" BFG muds on my '91 DD are at recommended 30f 35r.
My '78 on 33"s has 20 f&r and it's smoothed out the stiffer suspension a bit but does kind of wollow and bounce a bit!
