What all is interchangeable between pickups and k5's around 1975.
Morris75
Registered Member
Hey guys, just joined after purchasing a 1975 K5 Blazer. I'm curious what all is interchangeable between the two. Specifically I'm looking for:
Rear bumper
front turn signal assemblies
dash pad
instrument cluster
door guts (locks etc)
grille
I can tell they look similar but are they identical?
Thanks,
Not sure about the rear bumper,most pickups had a step & tow bumper,the "regular" bumper may fit,the brackets are probably different though..
The other things you listed should fit OK..door glass thickness changed somewhere in the mid 70's but I think the guts are the same...whole doors will fit off a pickup too,if its a '73 to '75 with the full roof,the door window frames will need to be trimmed off though..
Everything is the same as far as I know. The only difference would be the rear bumper like mentioned above
The bumper should work.
I know my dad had a back bumper from a suburban on his 85 short box but i can't remember if he had any trouble putting it on or not. I think it was a bolt on deal though.
Bumper brackets are different as far as I know, but bumpers should interchange to the brackets...
As far as I know...
