What all needs to be done when moving Axle forward?
Ben B.
Central PA
Like it says, will be investing in some Zero Rates soon.
Planning on running 38's with 4" lift + 0-rates.
Aside from the driveshaft needing lengthened, can i use stock steering or no?
To use pushpull (ie stock) steering, you'll hafta adjust the draglink, and it may not adjust enough without cutting one end or both -- read up on it, search terms like "cutting drag link" should work.
Depends on how much farther forward you go, and I suspect trial and error is in order.
But crossover really is much nicer ;)
-- A
Thanks for the reply.
I'm a poor college student. Is converting to X-over really expensive?
