Mentioned below are the common issues. On my 88, I have to bring the panel out from the bottom first, then fight with the steering column interference. Usually put a thin rag over the column first so I don't scratch it up.I got the bezel of, the gauge cluster is loose but I can’t get it out, its stuck behind the metal part of the dash. It’s like the hole for the cluster is to small… what is the secret?
