what are cross over steering arms made out of?
y5mgisi
1 ton status
Portland Oregon
Much more simple of a question than the last post. Any one know? Is thaere any heat treating that is involved? /forums/images/graemlins/ears.gif
I think it's just machined steel /forums/images/graemlins/waytogo.gif /forums/images/graemlins/dunno.gif
Most are plain mild steel. The differences I've seen are that some are flame cut, and some are machined profile. Some guys do use cold rolled steel...
Mostly the strength comes from it's physical size and thickness, combined with good machining practices.
Rene
my WTO steering arms are made from 1" thick cold rolled steel. Definitely stronger than the knuckle, especially when attached with ARPs high-zoot 190,000 psi studs. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
j
Pudding /forums/images/graemlins/histerical.gif Ok cool thats what i needed to know thanks guys.
I saw some 3.5" and 4" wide 1" thick flat bar that looked promising at the steel supplier the other day
weld a pipe cap for the spring pocket and call it a day
I went with 1.5 in. cold rolled steel bar, no way on god's green earth will my blazer ever bend these, prolly break a knuckle first /forums/images/graemlins/doah.gif /forums/images/graemlins/waytogo.gif
I saw one set out there in net-land made from 1" thick Titainium. Probably because he could.
