mine's a mechanical speedo. i got in the truck the other day and the speedo just didn't work. doesn't even bounce. i checked the connection at the t-case and i checked the connection at the gauge. only odd thing about this speedo is that it's got a gear-correction fitting on the t-case. could that go bad? i didn't pull it off and plug the speedo directly into the t-case to check.
what else should i look at?
