What are your current unfinished projects?
clean out a barn, clean out a machine shed from the 50's with nothing but rusted out crap, tear down a stupid giant wood ski jump that someone built for some reason :confused: tear down 2 garage sized sheds, get about 16 wheels and tires swapped around and balanced, rewire the garage, find an old s10 or mazda b2200 to make into a work truck, build a ladder rack for set work truck, fix the PTO snow blower attachment for the old john deer so i dont have to shovel a 3/4 of an acre driveway every 3 days this winter (we get a hell of alot of snow) and once everything is torn down I have to rent a big a$$ trailer or find someone who can haul away about half a garbage dump worth of crap from the barn machine shed and downed buildings... man... this is gonna be a busy and expensive fall...
Hey now thats not fair, if you've got a clean garage you aren't doing **** anyway...
True, but if you saw either of my garages you'd understand. It's hard enough to even walk into them let alone actually do anything inside with all the stuff laying around. Any work I do has to be outside. Even in winter.
i've got to fully re build a dana 60 from the ground up, i just got a 14ff that needs to be re geared, and cleaned up with discs.. then i got to take out the little 10 bolts, and throw the 1-tons under my 82 blazer, clean up the 52 in. spring i have, get some more lift stuff, and there is way more but i dont wanna list everything..
Cory
Well Kert and Stomper wont so I guess at least one guy from NW Iowa has to Chime in
83 GMC
- New Motor(CONVERT THE DAMN THING TO GAS), New Tranny, 3/4 ton axles, detroit in rear, 4 inch springs front, DIY4X shackle flip rear, decided what to do to the body, 35 or 36 inch tires, new rims.
86 Chevy
-New tranny, 3/4 ton front suspension, 3/4 ton rear end. new Rims and 31sfix the bode on that(god help me)
71 Chevy, get what rust there is, fixed profensionally, new rims, with DIY4X rim strengthers with Bowties in them. new tires, freshen up the old 350, check every little thing with it, and start putting it in shows behind either of the other two trucks on a trailer
-GET A TRAILER
96 Blazer...stop wheeling it and breaking it :crazy:
Find an acreage in the country somewhere and put up a nice shop, then fix up a old Farmall 560 with a loader too.
Oh and find a girlfriend for christ sakes
By the time im done with all this there problably wont even be a internet or CK5 anymore, specially the last one :doah:
5 years and counting on the blazer.... :mad:
dodge is comming along slowly, but drives
grant
wow you must get really good milage with that big cargo box on there. :haha:
when i saw this thread, i thought, wait till allan shows up. :haha:
for me?
let's see. get sammi greased. (i have a samurai. ok, 2 sammys) change oil, add lucas oil stabilizer.
fix a bunch of little things with that: heater, leaks in the interior. fix drivers window so it'll roll up and down without help, swap driver and passenger seats so i get the seat with no rips in it.
build bushguard, put on rock rails and rear locker.
fix rust holes in floor
get truck to bodyshop to put on rear bumper and stuff after i got rearended.
eventually re-do truck in LEDs and try out some 29s with stock gears and no lift.
try to get my friends dad to ok us putting my sammi #2 in his barn to build into a buggy. it was cheap but had no body. meaning no steering wheel, pedals, guages, seats etc. very easy to work on cause no body gets in the way. :D but also very rusty. i'm hoping that there'll be a frame left when we chip off all the rust. rear tires won't turn (both of them), gotta fix that. get motor running.
i have some moderate buggy plans for sammy #2.
as it is 12 mpg hand calculated through all terain types at 65mph. ill be making it more aerodynamic inthe next year, but i only have one more tow between now and then
Grant
pulling the tcase and tranny in my truck. Got everything ready to be dropped just need to get a tranny jack so I do not kill myself :D
