I have a, if I remember correctly a 96' 454 out of a 4x4 burb I got from another member a few years ago. It's complete and I have the harness & ECU thingy. It's going in my 73' K5. I want to swap it to EFI using a FAST system. I want to run bolt on out of the box Aluminum heads, probably a pair or Edelbrock's if they have a set that is just that, I figure they do. Probably run an Edelbrock manifold too. I want to run headers of course. I know I can ditch the stock exhause manifolds, scrap'um for cash along with the rest of my pile I build up and take in every once in a while.
My question(s) is I have a complete new E-Z wireing harness for my K5, Headlights to taillights. Do I still need to keep & use harness that came with the motor? Or, can I get a new harness that will tie into my new complete E-Z harness and work? I want 100% NEW wireing in my K5.
Should I scrap the stock heads or try and sell them? Stock manifold as well? I want to strip the motor down and then wrap it up cause it will be stored for a while till I'm able to afford the parts I want/need.
The motor was suposed to have only about 60K on it. I pulled a valve cover and the top of the heads look nice and clean. Zero sluge or build up at all. Or should I just do a full tear down, check all the critical clearences, re-gasket and re-bearing it, bolt it back together and run it?
Should I do a piston swap and bump up the compression? I don't have smog to deal with of course. I want a decent cam in it to build torque, that works with the EFI swap. I want a good reliable motor with more HP then the stock motor puts out. Have not even gotten into the bottom end to see if it's a 4 bolt main block. I don't need 5/600 HP so it doesn't need to be a 4 bolt main of course. I wouldn't mind that kind of HP but I don't want terrible gas milage either. It's going to get bad enough just being a big block.
Not sure what direction to go with this thing.
