gt1009
I've been having some issues with my truck's ignition lately, and now there has been a bigger issue where my oil pressure drops down to zero at idle. It acts normal most of the time sitting at about 10 psi at idle, which seems a bit low. but this weekend I took it on about a 50 mile trip, and after a few miles at highway speeds the check engine light came on. I didn't think much of it, but when I came to a stoplight the oil pressure went to zero, then the needle started waving back and forth. If I gave it a tiny bit of gas it would jump back up to about 10 psi. I'm wondering if my oil pump is weak, or if I'm having problems with my distributor, which would tell me why the truck seems to miss a cylinder under hard acceleration too. I checked the oil and it's full, so I'm wondering if I just have a faulty gauge or a bigger problem. Anything else I should check?
