I have a serpentine driven 350 TBI. I have an annoying squeak, not a constant squeal, but a repetitive, rotational squeak-squeak-squeak. It does it at lower RPMs, although I just might not be able to hear it over the engine at high RPMs. When I turn off the engine it lets out a last "squeeeee".
It sounds like it's coming from the balancer or the water pump pulley. The shaft that goes to the fan spins perfectly, but the water pump pulley has about 2mm side to side movement when running. The harmonic balancer spins perfectly.
I thought it was the A/C idler, (well it was squeaky too), so I replaced it, but something else is still squeaking. My belt is about 5 to 6 years old with probably 30k miles. Any ideas before I throw money and parts at it?
