what parts are you starting with? why are you thinking about swapping bodies? whats wrong with what you got now?
Get a cheapo 2wd s-10 xtended cab and swap your drivetrain into the s10. The s10 frame is stronger. Swap your rear springs to the front and make some mounts to hang them, link the rear (useing coils will bring the cost down) chop off rear frame and back-half it.
EDIT: maybe keep the springs in your k30 and just some cheapo 1/2 ton axles in it. Then it will be a roller and will be much easier to sell than just a body.
i love the way the full witdh look on a blazer body but thin that unless i used a blazer i would swap pickup bodies.....anyone want a clean body?
