We have an '07 Cadillac Escalade loaded to the brim and we love it.
1. Why do you want to use a tuner for it? This is the wife's ride right? I highly doubt you can get much more mileage than 1-2mpg out of it extra. How much will that cost you working with this shop to achieve that? How many years will it take to earn that back getting 5% better mileage?
2. I would just fix the auto ride system. You just bought a nice vehicle, why start "disabling" the things that make it nice?
Yeah the auto ride stuff is expensive, yeah the 6.2L is a bit thirsty.... but we bought these luxury vehicles FOR that stuff, right? Because if we didn't want that, a regular 'ol Tahoe doesn't have the bells and whistles.
I'm not being harsh or a jerk, just playing devil's advocate.
As far as the vehicle.... don't even worry about the body, at that mileage it should still feel new as far as doors, interior, etc. Same goes for the suspension and steering, assuming it saw normal use, you should not have to do any front end work for a long time.
Things to watch out for....
1. Front diff, mine had a seal out and was low on fluid. Change it, make sure it isn't leaking, and use synthetic since it calls for it.
2. Keep an eye on your cam shaft actuator. These 6.2's have variable valve timing, so the cam is actually adjusting it's timing on the go. When the actuator gets old it can get stuck in a certain position after running down the highway for a while, and sometimes even in town too. The oil pump drives it and the ports are tiny, they can get gummed up over time and impede it's ability to move freely. Our symptom with our Escalade was a stumble at idle that would drop off and die, no power in the low RPM when leaving a stop, and a no start at all after shutting it off from a long trip. It will restart after about an hour. It leaves no codes either.
This has driven us nuts, it has left us stranded multiple times and both my local Chevy and Cadillac dealers were practically worthless for diagnosing it. I'm the one that had to tell them to change the cam actuator and so far, 4 months later we haven't had any symptoms.
07-08 6.2's also can suffer from worn cam bearings on some of them. Supposedly the oil ports feeding them are under sized. I personally think there should have been a recall, but no. That problem "mysteriously" went away with 09 and newer 6.2 engines.
Outside of the issues I just described with our Cadillac Escalade, we LOVE it. So much nicer than our old '03 Yukon. Looking back, I wish I would have bought a newer '09-11 to keep clear of the problems on the early 6.2 but oh well. We plan to stick with Escalades from here on out for my wife's vehicle, can't beat them IMHO.
