45acpJr
Well I was putting the finishing touches on my 14 bolt, all I had left was put the axles back in and bolt it together. First side went fine, second side one of the 8 bolts felt a little tight so I backed off and blew it out. Tried again, still tight so I but the impact to it, and snap!! So after looking for a replacement I came across these.
http://www.ballisticfabrication.com/Aluminum-Full-Float-Axle-Hubs_p_1695.html
Problem is they are not cheap and reading thru it I need to change to a 35 spline. Worth it??
