Once I get a clear answer from Jet who bought TunerCat OBDII software I will know if I can make the changes needed to transplant this engine into another car. Seems 96-97 are odd years and all alone compared to 98 later and 95 earlier.
But maybe I should look into an older ECM? Or newer ECM? Manual transmission...
Basically upgrading to the '0411 PCM is using the same LS '0411 PCM used in the 2001 / 2002 Express Van with a 5.7 lite Vortec engine. When the old "Black Box PCM" is upgraded correctly, the LS '0411 operates the older Vortec engine like a factory installed Express Van engine. The advantage is the '0411 PCM can be hooked up to factory diagnostics (GM Tech2), and the '0411 PCM is supported by the aftermarket DIY PCM programming software hardware like EFI Live.
