What exactly does this tool do?
RustBuket
Saskatchewan, Canada
This may seem like a dumb question to some but what does this tool do?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32718&item=3874774673&rd=1
Also, there is a tool which I don't know the name of it but I believe it has the purpose of cutting thin sheetmetal kind of like a scissor. They have one on monster garage and I think its pneumatic. The metal thats cut comes out in a thin strip and coils up. What is that tool called? looks handy. Thanks.
.... the tool you described is known as a nibbler... look at the name of the tool on there. There are lots of ways to cut sheetmetal, there are electric and pneumatic shears, as well as electric and pneumatic nibblers. You are probably thinking of the shears. But a nibbler is a good tool, sometime I will get one, can make better curves and such with it.
i own both an air nibbler and air shear... the shears make the coiled strip.. nibblers make tiny halfmoon chunks...
We have one and it was a whole lot less money than that one. (Can't remember but maybe $100.00 maybe $150.00. at local tool shop.
It has a plunger shaft about 3/16" maybe 1/4" that goes up and down and pushes into a hole. The plunger nibbles off about a fourth of a hole of 3/16". Which it punches out half moon peices. Rapidly. It does not warp the body metal that it is cutting. works good on long quarter or long body part because of no warping of the sheet metal edge.
The only bad part is you have a whole lot of half moon pieces that are very sharp and get stuck in every thing. Shoes, hose, tires, hands. but if you clean up right away than there is not problem.
I like the one we have. Especially like i mention working on long body parts like rear quarters because on the non warping edge it leaves.
87 K5
thank you
stano
Those things work great, I trimmed my inner fenderwells with mine. Makes quick work of it and turns super tight corners. Don't walk in the garage in bare feet after using it though...:blush:
i cant stand wearing shoes in the summer. i weld,cut,grind,wrench,walk,run do everything barefoot. last time i went to chicago i forgot my shoes at home so i had to by some flip flops. any way, i was thinking of getting some nibblers. anybody have experiece with both tools(nibblers and shears i think there called)?
i have experience with nibblers, shears, cutoffwheel, jigsaw, sawzall for cutting sheatmetal. the nibblers are the easyest to follow a line of anykind, straight or curved. the shears work well too and can cut a little bit thicker metal but dont pivot/ turn aswell as the nibbler. Cuttingsheetmetal with cutoffwheel. jugsaw or sawzall is alsogood too becasue you can cut alot thicker metal with a decent amount of control.
sheetmetal - NIBBLERS DEFFF
