The fan you linked is clock wise or standard rotation if you have serp system like me you need reverse rotation.
Thanks for the reply but im pretty set on sticking with traditional blade and clutch.I have a flex a lite fan with a spacer, no clutch, My engine is a 93 TBI 350 and never a problem with cooling. I do have a 4 core radiator too. I will have to see which fan I have. Seems like it was a 7 blade. I have been running it for about 11 years.
Yeah your engine there was a six blade fan I had that was the ticket. I don't remember if I gave it away or scrapped it at one point or I would dig it up for you.Thanks for the reply but im pretty set on sticking with traditional blade and clutch.
As for the 7 blade and 5 blade they were interchangeable same diameter.
I had both and when I got the chance I always used the 7 blade.
I just had it on a vortec 350, didn't get the vehicle with it.Any idea the application the 6 blade was used for? Still looking
Interesting option.The other option, is to run the 11 blade Vortec 5.7 liter plastic fan. The Vortec fan is attached to a fan clutch, that threads onto the water pump. The bolt pattern, where the fan bolts to the clutch is the same, so you can bolt the Vortec fan to a tbi fan clutch, and put it into the original fan shroud. I have a 78 k5, with an 89 Tbi engine, with an 89 heavy duty fan clutch, with an 11 blade Vortec fan, in the factory fan shroud. 95 degrees with the a/c on, at 1mph 4wheeling, is no problem!
