What gauges are these?
Pretty sure there are knock off versions.
I’m not a fan of digital. The numbers are always changing which makes it harder to see at a glance. Analog is better because once you know the scale and sweep you can quickly tell from there peripherals where you are.
Easy.... Volts, oil, fuel, water,MPH and RPM..... It says it right on them.:D
I'm torn on what to do myself. Right now I've got an AEM wideband in my blank spot, 3 pod under dash(half works), and a crappy tach on the column. I go back and forth on the different dakota sets. With the LQ4/4L80E, I like the idea of the HDX's but not sure if I can justify the money vs the VHX. Even those are pretty pricey. A lot of the time I bring a tablet with me and connect to ELM through bluetooth. I'll use the torquepro app and can moitor dang near everything. I am tempted to build a cluster to house a tablet and go that route. Not sure how I would address the fuel level though.
So on a serious note.. if i ever do the 8.1L swap in a few years...i thought of putting an android tablet in dash with torque pro...
This is what I am going to do on the Buick. Plu,,q s have the factory speedo converted for vss feed.
